Getting transmission rebuilt.....
Rebel
Re: Getting transmission rebuilt.....
Post by Rebel »
Job is done, I will be picking the bike up on Tuesday. They did install the circlip on the output shaft and said everything looked very good. Can't wait to get her back, Spring is almost here!!
AMA Charter Life Member
Now: 1983 Yamaha XV-920MK Midnight Virago with Factory Touring Package
Then: 1987 K-75S, 1988 R-100RS,Triumph T-140D, Harley FXDB Sturgis,Triumph Speed Triple,Triumph Bonneville, Moto Guzzi Norge, Yamaha FJR-1300, Victory Vision...
enigmaT120
Post by enigmaT120 »
Was it under a thousand bucks?
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
Rebel
Post by Rebel »
I wish. The total bill was $1466. The job was not only the transmission bearings, but also to cut the groove in the output shaft, install the circlip, installation of a new rear main seal, check and inspection of the oil pump, and the installation of a new throw out bearing. I was anticipating a rather tall bill with the machine work on the output shaft. Hopefully the job will last for another 120,000 miles. I will post more information once I get her back.
George Ryals
Post by George Ryals »
Rebel, can you tell from the bill what the cost of the trans rebuild would be without the labor to R & R the trans?
Smile it's contagious!
'85 R80RT wreck for parts
Rebel
Post by Rebel »
Hi George,
I can't yet, I won't have the bill until I pick it up. Once I see the itemized charges for the service, I will be happy to post them.
Rebel
Post by Rebel »
FYI George:
Here is the list from the dealership on the repair:
1 ea. o ring #11411335895 $3.77
1 ea. shaft seal #11111338342 $26.77
1 ea. 11221337093 whatever THAT is $3.68
1 ea. shaft seal #23121338726 $9.71
1 ea. shaft seal #23121232681 $15.42
1 ea. switch #61311243097 $35.93
1 ea. gasket ring #61311355262 $.73
1 ea. gasket ring #07119963200 $.37
1 ea. gasket ring #07119963300 $.58
1 ea. cylindrical roller bearing #23211235449 $125.03
2 ea. 23121231495 whatever THOSE are $33.30
1 ea. grooved ball bearing #23121233808 $24.36
1 ea. grooved ball bearing #23121338795 $41.39
6 ea. fillister head screw #21211338680 $10.80
6 ea. washer #21211242377 $4.02
1 ea. spring #23311242910 $1.99
1 ea. diaphragm spring #21211338508 $60.65
1 ea. lock ring #07119934100 $.74
1 ea. piston #23131464167 $72.24
1 ea. shaft seal #23121338740 $8.14
1 ea. shaft seal #23121242522 $18.01
1 ea. cup #23131338731 $39.24
1.25 synthetic gear oil 75W-140 $30.68
machine groove in shaft $40.50
Parts $567.55
Labor $792
Shop supplies $10
Tax $30.61
Total $1440.66
I tried to look up a lot of these part numbers and could not find all of them. Anyway, she is home now and feels very smooth with the transmission. Come on warm weather!!
George Ryals
Thanks, Rebel this is a big help to me. Looks like he only charged you for 5 bearings, I wonder which one he didn't replace.????
Rebel
Post by Rebel »
You're welcome George.
From my understanding all of the bearings in the transmission were replaced, as well as the throw out bearing for the clutch. Hopefully everything will be fine for a while after this.
Did the shop suggest an oil change after a few hundred miles?
Rebel
Post by Rebel »
Hi Duane,
They did not suggest that since no other changes were made. I plan on at the very least dropping the fluid to check the magnet on the drain plug for any signs of metallic paste.
