oil leak from Clutch Arm
Re: oil leak from Clutch Arm
This tranny has a felt, and not a rubber boot to prevent oil leaks?
I reckon the tranny is leaking at the clutch push rod.
Seth
Post by Seth »
The felt (fiche part number 2) is on the outboard side of the rod, inboard of the plunger. There is also a seal on the outboard side of the plunger followed by the rubber boot. The felt doesn't really seal the oil. It's more like a dampener for the rod to the plunger. The seal (gasket ring part number 21 52 1020109) does the job.
