Disc drag
Re: Disc drag
barryh wrote: Tue May 30, 2017 5:42 pm
Zombie Master wrote: Tue May 30, 2017 5:08 pm . When you say silicone "grease" spray, is that the same as light silicone spray? :ugeek:
It's real grease and much thicker than light silicone spray especially when the solvent carrier has flashed off.
Sounds like a useful product, haven't seen it in my local. :|
dougie
Re: Disc drag
Post by dougie »
I use Dow Corning 111 compound for all things rubber. Heavy bodied silicone grease with a very wide heat tolerance range.
Bought it at a bearing supply.
Re: Disc drag
I've got some pricey synthetic brake lube. It better work!
Ken in Oklahoma
Re: Disc drag
Post by Ken in Oklahoma »
Zombie Master wrote: Thu Jun 01, 2017 3:47 am I've got some pricey synthetic brake lube. It better work!
Wow! I was thinking of opening up a little synthetic brake lube stand in front of my house to pick up a little change. But after reading the above I think I'll open up a lemonade stand instead.
Uh, you don't drink lemonade do you? :lol:
Re: Disc drag
Ken in Oklahoma wrote: Thu Jun 01, 2017 6:09 am
Just as long as you don't put in any covfefe sweetners! :|
