Help Need Information Deferential Swap .
bmw22
Post by bmw22 »
I want swap R80RT cast wheel in to R90S, R80RT wheel not fits R90s Deferential,
R80RT deferential bolt on to R90s swing arm ?
Thank you.
RPGR90s
Re: Help Need Information Deferential Swap .
Post by RPGR90s »
huh?
If the R80RT wheel comes from a Monolever bike (single sided swingarm, 1985 and up) you'll need to swap the whole R80RT swingarm on and work out how to mount the upper side of the shock absorber. It will take frame and subframe modifications.
If the R80RT was a dual shock bike I think you need to change the brake shoes as well as the wheel. I think the width of the shoes are different.
Assuming you're referring to a wheel and bevel box from a monoshock machine, while the bevel box will bolt up to the R90s swing arm, this isn't a practical proposition because:
a) You won't get the wider tyre to fit between the brake shoes and the left hand side of the swing arm and
b) because the left shock absorber on the R90s swing arm attaches to the left arm of the swing arm which would be unsupported and
c) the swing arm used on the twinshock bikes isn't rigid enough to support a single sided swing arm application.
You could try looking at the rear wheel from a R65LS which is also a 'Y' spoke wheel, albeit with 5 sets of spokes rather than four. You would have to check the rear brake as I believe that this is different for this model.
If it turns out you're referring to a 'snowflake' wheel from a twinshock machine, then this should fit straight up to your R90s bevel box without issues. As far as brake shoes go, even though the shoes changed for the 1980 year, the wheels didn't... so that implies that the later wheel can be used with the original shoes.
bmw22
Post by bmw22 »
My main question, 1986 R80RT (single shock) rear Deferential fits R90S ? I want convert "Y" wheel to my R90S. Thank you.
bmw22 wrote: Wed Oct 13, 2021 11:07 am My main question, 1986 R80RT (single shock) rear Deferential fits R90S ? I want convert "Y" wheel to my R90S. Thank you.
See the first part of my previous response. It won't happen without some fabrication and using the whole R80RT single sided swingarm.
The simple answer answer is NO. At least not without a lot of engineering...
