While I am waiting, I decided that I needed to put some locktight on the bolts that hold the clutch assembly to the flywheel. I chickend out the first time at around 12 foot pounds when I put it together. I pulled one bolt and was putting it back. Somewhere just over 10 foot pounds I heard and felt a pop. The bolt backed out easy enough, but it was clearly deformed. The threads look undamaged.
Knowing I was getting new bolts anyway - I pulled another one and put it in the vice. At 12 foot pounds it twisted off. The comparison is not quite right as the bolt was supported in the vice on only two sides rather and uniformly, but its still scary.
The book does not say anything about replacing these bolts. Is there some general rule that says I should? The book also says 17 foot pounds. Does anyone know if this is wrong?
