OK, I get the idiot of the day award. While working on my bike I bumped into a 8' 2x6 I had carelessly stood up against the wall. Somehow it fell in slow motion toward my bike. I deflected it away from my tank at the last second only to have it land squarely on my tach. Needless to say the glass is no more, but no other damage was done.
Anybody know where I can get an 85mm disc of glass to replace it? It doesn't need to be antiglare. I think I can reuse the bezel. Can a local auto glass shop cut such a thing?
My Speedo lens was shattered when I bought the bike 21 years ago. I replaced it with an old lens with a chrome bezel off an Austin Healey. Fit like a glove. A pity I don't have another one of those.
Tach lens shattered!
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
dwerbil
- Moderator
Re: Tach lens shattered!
Drop Matt a email or try Mikey at Martindale Cycle Works.
I made a lens from plexiglass for my /2 about 6 years ago. It still looks good. It is under a fairing though and sees very little UV.
If you go that route, I would suggest Lexan. More $, but more scratch resistant.Garnet wrote:I made a lens from plexiglass for my /2 about 6 years ago. It still looks good. It is under a fairing though and sees very little UV.
What method did you use to cut it? I have drill press.dougie wrote:If you go that route, I would suggest Lexan. More $, but more scratch resistant.Garnet wrote:I made a lens from plexiglass for my /2 about 6 years ago. It still looks good. It is under a fairing though and sees very little UV.
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
I used a bandsaw and then wet sanded the rough edges. I glued it in with Permatex Super Bonder.
Follow Doug's advice and use lexan. To be truthful, I don't know what kind of plastic I used. I bought a scrap at the local plastic store, and to me clear plastic is plexiglass.
The plastic store will cut it for you for a fee.
dwerbil
- Moderator
Just a thought....clear lexan may be had at your local outfitter store, i.e...REI, Whole Earth Provisions, in the utensil section -- a lexan dinner plate. Maybe there's a clear one to be had, for under ten bucks.
- George Ryals
Big Box home improvement stores have Lexan in 8" X 10" sheets and up. I think the small sheets are .110" thick.
Smile it's contagious!
'85 R80RT wreck for parts
Got an 8x10 sheet of lexan at the local hardware for less than $4.00. Ran into an airhead friend in the parking lot. He told me a local glass shop cut him a glass one for under $5.00 a year ago. I'll check into that.George Ryals wrote:Big Box home improvement stores have Lexan in 8" X 10" sheets and up. I think the small sheets are .110" thick.
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
