Red line ?
- Sibbo
Red line ?
How often do you take your BeeM up to the redline .... or past it ? I saw it a few times yesterday,once in top gear, right on the 7000 rpm .
The Grateful Dead
The Grateful Dead
Re: Red line ?
I have seen 61/2k on the tacho.Sibbo wrote:How often do you take your BeeM up to the redline .... or past it ? I saw it a few times yesterday,once in top gear, right on the 7000 rpm .
Re: Red line ?
Occasionally, and usually going up a big hill like Mt. Hotham or somewhere in the Snowies. When I do that, it redlines a lot! I don't go over if I can help it..Sibbo wrote:How often do you take your BeeM up to the redline .... or past it ?
Re: Red line ?
When riding up or down Palomar Mountain, it gets to redline and is near it a lot. Around town, I'm sedate but don't stay in high gears. I don't like lugging engines and the little bit lower gear means quicker engine response.
- Sibbo
Re: Red line ?
I've been very surprised how freely Tilly revs, I usually keep it moderate but I had to get out of the way of a car yesterday and the 7000rpm came up very quickly ! I was keen to shift .
Then I was having a run at top speed ,I got 145km at 7000, just before the red ..I didn't want to push her beyond that .
The Grateful Dead
The Grateful Dead
Re: Red line ?
I saw just over 8000 the other day. (first time)
Just how much of that was inertia of the needle?
Red line at 7000 lots in the mountains, but usually not much more.
33/11 RS is about 180 at 7000 in 5th.
Re: Red line ?
Got up to 176 kph last week before I chickened out (didn't look at the tach)ME 109 wrote:I saw just over 8000 the other day. (first time)
- Sibbo
Re: Red line ?
I need 6 th or a longer 5th . I get 145km at around 6900 .She spins up fast 'cos she's so undergeared, nice on the hills though . Not so good on the flat .ME 109 wrote:I saw just over 8000 the other day. (first time)
What do you spin at 100 km ?
The Grateful Dead
The Grateful Dead
Re: Red line ?
I don't have a functioning tach on my conversion or my /5 but both have the same 72 R75 engines. I will rev them in lower gears till they run out of breath which is probably around 6500ish RPMs and sometimes beyond.
Stock valve train will take 7500ish before it begins to float. With a 336 cam the engine is making good power above 7000 so it is worthwhile lightening the valve train to make it safe up to 8000.
Re: Red line ?
I've only taken notice about 5000 times. I think it's 3800 @ 100k.Sibbo wrote:
Then there is also the inaccuracy of the speedo to consider. Mine is about 10 k optimistic.
