Drive shaft boot leak
Re: Drive shaft boot leak
Post by Rob »
Kurt in S.A. wrote: Sun Aug 13, 2017 4:34 pm The boots do have notations for front (getriebe for transmission gearbox) and top (oben).
voted best answer
robert
Post by robert »
Check for cracks on the flange.--RG
I think I figured it out: The clamp normally would have an extension piece spot welded to the clamp in order to maintain clamping pressure in the area not covered between the screw and threaded attached nut. The spot weld mark is there, but the piece is gone. I've attached the thin tapered end of a zip tie to cover that distance and it seems to be dry so far. I will order some new clamps. I wonder if a zip tie alone, could be tightened enough to seal the boot.
robert
Post by robert »
A couple of zip ties should work. --RG
You lost your clamp extension. :roll: Mine's been loose for twenty years. It requires a special technique to get the little bastard back in when tightening the clamp. :geek:
That'll be your leak.
Post by Rob »
I had never seen a clamp come apart. I never would have suspected that.
ME 109 wrote: Mon Aug 14, 2017 3:54 am You lost your clamp extension. :roll: Mine's been loose for twenty years. It requires a special technique to get the little bastard back in when tightening the clamp. :geek:
Yea I lost the extension. Trying to order new clamps from the stealer. :?
