Anything that changes the the tire contact patch point on the ground in relation to steering axis changes the trail.vanzen@rockerboxer.com wrote:So, like this, right ?robtg wrote:With the axle it the center of the leg and less offset in the triple clamp you would have more trail.
The shorter fork will increase steering head angle a bit and reduce trail, but not by much.
Overall trail should be increased.
The Duc increases trail by virtue of a lesser ("0") axle offset.Chuey wrote: The axle is in the center of the fork, whereas the BMW axle is on the front of the fork leg, so further forward.
Also the Duc increases trail by virtue of a lesser fork offset.Chuey wrote:The Ducati fork has less overall offset. In other words, it does not end up as far forward.
Less T/C offset, moving the axle to the center of the slider, move the wheel to the rear increasing trail.
