Elementary question - leaky carbs
Re: Elementary question - leaky carbs
Oh, I forgot to mention, it ran really nicely when I started it up. The only thing is it was leaking gas from the carbs.
Darryl Flynn
Post by Darryl Flynn »
Sticky float needle. 100%
Darryl
My other bike is a Guzzi
I've had a nice idle with fuel pissing out of one or both carbs.
How old did you say your needles were Chuey? As has been said, start with new needles to make an assessment.
It is indeed unlikely that the seats are the problem, unless someone like me has been in there. :?
My float pins are now removable either way, as they have been out that many times. :?
It doesn't really matter if the pins are loose because they can't come out when the bowl is in place. The bowl is about 2-3mm from each end of the pin. The best thing about a unidirectional pin is that there is no....er, what way does this thing go again... :roll:
The hair springs that hold the needle to the tang (if you have them) are a pita. The carbs will function perfectly without them.
Flamin' Boots.
lrz
Post by lrz »
Been roofing all day; here's that link:
http://www.bmwmoa.org/forum/showthread.php?t=60489
Pretty lo-tech.
Re: That link was a trip!
I liked it when one of the comments said he was a "little leary". I guess you never know when someone will drop acid and decide to rebuild BMW carbs. Wow! It's like a whole universe in that float bowl! Those floats are so beautiful! Wow, man.
I'm pretty sure it's just some stuck needles. I'll dig into it tomorrow morning.
Chuey wrote:I liked it when one of the comments said he was a "little leary". I guess you never know when someone will drop acid and decide to rebuild BMW carbs. Wow! It's like a whole universe in that float bowl! Those floats are so beautiful! Wow, man.
After the effects of the wine, I hope. ;)
ME 109 wrote:I've had a nice idle with fuel pissing out of one or both carbs.
Flamin' Boots.
I just dug my winter /5 out of mothballs and am not allowed to leave my boots (left one) in the front hall closet. :oops:
Maybe I'll fix it tomorrow with Chuey. But it's supposed to be sunny................. :? :?
Chuey wrote:I'm pretty sure it's just some stuck needles. I'll dig into it tomorrow morning.
'Course there's always the possibility that some crud from the tank or a bit of fuel line has got itself stuck in the seat where the needle contacts. I've had that before.
Sometimes allowing the float to drop all the way down and turning on the fuel will flush it out.
Otherwise disconnect the fuel line where it enters the carb and give it a shot of compressed air where the needle goes.
George Ryals
Post by George Ryals »
The float level could be too high and the leak is the overflow. or the float could be sinking, causing a high level in the bowl to be too high.
khittner1
Post by khittner1 »
Chuey----It may be the float needles/seats as others have suggested, but there may be a more elementary cause for the leakage---are you sure that your leaking problem isn't from shot or misaligned float bowl gaskets? I've found that whenever I pull my float bowls off, there's about a 1 in 4 or 5 chance that I don't get the bowls and gaskets just right, with fuel leaking onto my toes (or a puddle under the affected side) being the first indicator. Fresh float bowl gaskets, fully tucked into their retaining grooves on bottom of the carb bodies, might be a problem-solver if you're lucky.
Konrad
