R75/6 straight line stability
Re: R75/6 straight line stability
Major Softie wrote:
ME 109 wrote: Yep, pump those tyres up. I run about 35/35
If there's still a problem, then fork alignment is next.
Edit, based on running new tyres.
Since the tires are new, after pressure, my next check would be tire mounting: a tire not fully seated on the bead. Much more likely with tubeless, but can happen with tube sometimes as well. After that check, THEN I'd go alignment next.
A tyre not fully seated at 60-75 will feel like a jackhammer, but with sufficient air pressure should not "squirm" ime.
Squirming is flat tyre territory , or melted bitumen, or that rubbery shit they put in alpine road cracks. :geek:
Try home mounting a pilot active on a rear snowflake. They can be very difficult to fully seat the bead, even with a tube.
And a big compressor.
Breaking the bead is also not easy.
Less than ideal actually for a roadside repair if you run tubes.
Rebel wrote:How are your rear splines?
No affect on rear wheel wobble from splines.
Wheel bearings, spun wheel bearings or swing arm bearings affect wobble.
Abstruse1
Post by Abstruse1 »
I didn't inspect them carefully, but didn't notice any damage. I'll get the bike out today (I hope!) for a test with the higher tire pressure.
Abstruse1
Dallas, USA
Blonds aren't the only airheads.
Abstruse1
Post by Abstruse1 »
Aired tires up as suggested. Got out for a brief ride yesterday, abt 10 mi at speed. Handling seemed fine. Stay tuned.
Abstruse1
Dallas, USA
