I can't resistGarnet wrote:mattcfish wrote:Are we slipping into the dreaded resister vs non-resister plug discussion?
God no! I think that is overblown, just ramblin on.
Dual plugging: 14, 12 or 10mm?
Re: Dual plugging: 14, 12 or 10mm?
I have run both in most all of my airheads and not noticed any differance on the butt dyno chart.
On a dual plug setup I would imagine it would be best to run both plugs the same, that is both resistor or both non-resistor.
AND, these bikes were originally setup to run with non-resistor plugs and resistor caps. You could run resistor plugs and non-resistor caps and have the same results.
On a stock bike most likely yes.Major Softie wrote:AND, these bikes were originally setup to run with non-resistor plugs and resistor caps. You could run resistor plugs and non-resistor caps and have the same results.
That starts to get tricky if you are useing an aftermarket electronic ignition.
Boyer for example specifies a 5K ohm resistor cap for use with thier Micro Digital units. Resistor plugs have only a few hundred ohm resistance (I think), which may not be enough to not damage the control unit.
Yes, it was supposed to be implied that matching the resistance can be important for some systems, but I did not know that resistor plugs are that much lower than the 5k caps.Garnet wrote:On a stock bike most likely yes.Major Softie wrote:AND, these bikes were originally setup to run with non-resistor plugs and resistor caps. You could run resistor plugs and non-resistor caps and have the same results.
