I did this with my old Triumph TR6C when I rebuilt it. I recall I had the idea that I could improve the reliability and simplify, and it worked.I wish I knew now what I didn't know then.Ultimately, though, we might choose to define our own compromise between system efficiency and service efficiency,
even as the specifics of that definition will also re-define the parameters of a necessary level of "personal involvement".
But then you will know that this trade-off / balance is always part and parcel of "hot-rodding", eh ?
another hair brained idea
Re: another hair brained idea
Ditto that Twist
Triumph parts are about 1/2 the cost of BMW parts
And you can build a 283 Lb 70 Hp Triumph
BUT like a Sportster about the same level of comfort
Always wondered whether anybody ever put the necessary steps and mods on paper for the RT spider?twist wrote: ... to install an S fairing using a modified RT main fairing bracket, so the S fairing will be mounted to the steering head, not the handle bars.
Stephen
Re:re-post of photo
I'm not sure if this will be relevant but I tried to put this here the other day and discovered it didn't make it.
This is a shot of the underseat of my Cafe' Racer. You had mentioned putting wiring under the seat and this is just a reference.
Re: Re:re-post of photo
No problem with the reg / rec being under the seat with a minimum of cooling airflow ?Chuey wrote: This is a shot of the underseat of my Cafe' Racer. You had mentioned putting wiring under the seat and this is just a reference.
I am considering mounting mine under the gas tank and would appreciate your thoughts ...
( a very tidy arrangement, yours, by the way)
I had originally planned to put the R/R under the seat pan, but still very much in the air-flow,
then reconsidered the location as a matter of consolidating all of the electrics
(with the exception of tail-brake light and associated wiring)
to a place above & / or in front of the engine block.
thanks Chuey! I have something along those lines in mind and would like to ask you a few questions if you don't mind. BTW I'll be coming thru your area in Feb or Mar on a trip to San Diego fro Death Valley. Maybe we can meet up for refreshment?Chuey wrote:
vanzen@rockerboxer.com wrote:No problem with the reg / rec being under the seat with a minimum of cooling airflow ?Chuey wrote: This is a shot of the underseat of my Cafe' Racer. You had mentioned putting wiring under the seat and this is just a reference.
Although this is a /2 frame, it is under the seat just in front of the battery, behind the engine.
It never gets warmer than body temp.
Photo showing the location
of my Reg/Rec.
About the only place I could find that
had airflow, rubber mounting and close to the battery.
of my Reg/Rec.
3/85 R80 Mono
5/81 R100RS - Shed Find
kutter
Rockhampton
Queensland
Australia
kutter
Rockhampton
Queensland
Australia
Vanzen, I don't think that unit gets very hot. It has been a very nice part that has given no trouble at all. It may be cooler under the seat than I figure. Thing is, I thought the underseat exhaust would get hot and need venting and/or insulation but it doesn't even get very hot to the touch on the body work. I will probably still cut some vents in the behind the seat hump but they will be a styling thing if I do it. I did get some insulating stuff for the wires that run very close to the mufflers. Some of it came from Watson's Street Works. Some other stuff I got is better but it was a sample from a friend who was repping it.
frame mount S / mod RS bracket
A well used and battle scarred modified RS bracket for frame mounting an S fairing:
RS bracket required a bit of notching to clear clips / mc,
upper bracket is seen attached at top of H-light bucket: Detail of lower mounting "post" & carriage pin: In it's youth, holding a carbon fiber S-fairing w/ flush headlight, modified Duc 900 windscreen:
