You ball sounds good to go ZM!
On oil filter change
Re: On oil filter change
Confucius say, virtuous man who pokes balls with chop stick is most rikely still virgin rather than morally exerrent.
Did you check the canister depth? Most important part of the whole exercise...Zombie Master wrote:
I used a wooden chop stick. Had the nice flat end. The ball is still n place with light spring resistance. I installed the filter with new white O ring, new shim, and new gaskets on the filter cover and sump plug. I am most virtuous.
http://www.largiader.com/tech/filters/canister.html
Did you check the canister depth? Most important part of the whole exercise...DanielMc wrote:Zombie Master wrote:
Now you tell me
On a serious note, when I checked my most recent purchase, an '86 mono, I found the gap too big (according to Anton's advice) and ended up ditching the gasket and adding a shim. Mind you as the bike had already covered over 40,000 miles without incident there was every likelihood that there wasn't going to be a problem...Zombie Master wrote:
Now you tell me
