Even in the absence of defining that "golden rule" for himself – Rob said "sometimes".justoneoftheguys wrote: I shoot for the Golden Rule most of the time, but sometimes I miss the mark...
Conversely, I will always say just what I am thinking –
Is that a put-down?vanzen@rockerboxer.com wrote:Even in the absence of defining that "golden rule" for himself – Rob said "sometimes".justoneoftheguys wrote: I shoot for the Golden Rule most of the time, but sometimes I miss the mark...
Dang... really? ...well, that's it, I'm outta here!dougie wrote:Simple.
One rule.
Don't be an asshole.
Nope. It was just to accentuate the difference between your "sometimes," and his "always." You "sometimes" fail to meet the standards of the Golden Rule. He "always" says whatever he is thinking. To clarify, you sometimes fail to consider others, he never does. Doesn't mean he's being an asshole, just means he isn't filtering, while you are.justoneoftheguys wrote:Is that a put-down?vanzen@rockerboxer.com wrote:Even in the absence of defining that "golden rule" for himself – Rob said "sometimes".justoneoftheguys wrote: I shoot for the Golden Rule most of the time, but sometimes I miss the mark...
Help me out here, MS...
Sorry, you can't leave just because of that. Leaving just cause you're an asshole would be being . . . an asshole.Tim Shepherd wrote:Dang... really? ...well, that's it, I'm outta here!dougie wrote:Simple.
One rule.
OK, sortedvanzen@rockerboxer.com wrote:No personal offense was intended, R85/8R85/8 wrote:...I was after information, not insults.
Lovely fairing - but only available to the USA.twist wrote:rs fairing for sale. just sayin
http://cgi.ebay.com/ebaymotors/BMW-R100 ... 3f0df79d30
You will find carbon fiber very difficult to work with. Most of the pros don't try open molding with it. It is too stiff to "lay down" on an open mold, and won't go around corners, either male or female, without a second mold or vacuum bagging to hold it in place during cure.R85/8 wrote: One of the things I'm considering is applying a layer of carbon fibre cloth to inside of the existing fairing to reinforce it. Then the brittleness won't matter. I'm pretty sure epoxy will do the job. I'll do a test piece on the worst part once I have enough bits to spare.
