R75/6 LED turn signals. Dash light won’t flash
Posted: Tue Sep 23, 2025 12:32 am
Hello. I am a new member and new to BMW bikes. I have owned several english bikes and restored a few old Triumphs so motorcycles are not new to me and I have some mechanical skills.
I am in the process of converting this 1976 R75/6 over to LED bulbs and i have run into an issue which i have not been able to resolve by searching online.
I have installed 4 new LED turn signal bulbs from Euro Moto Electrics along with the new LED compatible relay. With the new LED bulbs and relay, the turn signals flash fine but the turn signal dash/dummy light is constantly illuminated. Prior to switching out my incandescent bulbs for LEDs I did not have this issue. What may be more telling is that if I put incandescent bulbs back in with the new LED relay, the turn signals flash as indented as does the dash/dummy light.
Right now I have an incandescent dash light in but I do have LED which I have tried and it does not make a difference…. The dash light for turn signals is always illuminated.
If I take the black wire with a white stripe and piggyback it off the green wire with yellow stripe, the turn signals flash as intended as does the dash light but when I switch the turn signals off, the dash light continues to flash.
I don’t believe it’s the relay as I have now tried two, 4 pronged LED relays with the same results.
I have also tried only having bulbs in the left side and then only the right side and then only in the rear position and the only in the front position…. No of these scenarios change the issue that the turn signals flash dash/dummy light will not flash with the relay hooked up correctly.
Brown = ground
Green with yellow stripe =49A on old relay to49A of the turn signal switch
Green with black stripe = 49 on the old relay to 15 on the circuit board. I believe this is the positive lead
Black with white stripe = KBL to the dash turn signal warning light.
On the new 4 pronged relay (EP29 model) I put the brown wire to the ground terminal, green with black stripe to the positive terminal, green with yellow stripe to the lamp terminal and the black with white stripe to the sense terminal.
Any help or suggestions would be massively appreciated.
Thank you,
Jordan
Brown = ground
Thank you,
Jordan
