Page 1 of 3
What's the Preferred Fuel Line Crossover Method?
Posted: Wed Oct 23, 2013 6:24 pm
by captmako
I'd like to run tees off my petcocks to have mutual fuel lines to both carbs. I have seen tees and lines run behind the airbox; over the top of starter cover; through starter cover......
Is there a preferred method for running crossovers?
Re: What's the Preferred Fuel Line Crossover Method?
Posted: Wed Oct 23, 2013 6:26 pm
by chasbmw
Why not use the BMW method?
Posted: Wed Oct 23, 2013 6:32 pm
by Jeff in W.C.
chasbmw wrote:Why not use the BMW method?
And what would that be?
Not that I'm an expert, but almost every bike I've seen (airhead that is) has it running behind the airbox.
Posted: Wed Oct 23, 2013 6:35 pm
The usual BMW way is to run the crossover fuel line between the lower front of the airbox and the gearbox.
http://www.advrider.com/forums/showthread.php?t=703807
Posted: Wed Oct 23, 2013 7:01 pm
by vanzen
I've always preferred the "X" fittings
as used by Moto Guzzi
but BMW's (as stock) "H" routing
is well suited to the powerplant's geography.
Posted: Wed Oct 23, 2013 9:06 pm
by Airbear
I run mine around the back of the clamshell airbox. It's just easier.
Posted: Thu Oct 24, 2013 2:57 am
BMW made holes in the airbox just for the fuel lines. By far the most important aspect is to make sure that one has enough fool flow to insure that a low point in the line isn't clogged up.
Posted: Thu Oct 24, 2013 3:04 am
Duane Ausherman wrote: By far the most important aspect is to make sure that one has enough fool flow
I got that in spades.
Posted: Thu Oct 24, 2013 5:09 am
by Zombie Master
ME 109 wrote:Duane Ausherman wrote: By far the most important aspect is to make sure that one has enough fool flow
Rather.
Posted: Thu Oct 24, 2013 9:27 am
by jagarra
MY crossover line looks to be made of different material, has no cloth covering. What is used as a replacement?
