Engine alignment in frame
Posted: Sun Feb 01, 2015 4:28 pm
Hello again. I have been getting ready to replace the timing chain, tensioner, spring and I guess the crank sprocket and bearing on my early number 1970 SWB r75/5. All numbers match.
Today's question (trying not let the Super Bowl distract me) is about the motor in the frame. It looks like is is about 5mm closer to the right hand frame loop than than the left. In fact it is as I measure it. Is this out of scope? I've ridden the bike 5 years in ignorance of this. There are spacers at each mount point as well as punched steel flanges on the forward mounts so I theeeeeenk everything is there. I've been playing with string to check the frame and it looks good. No crumple marks anywhere. I had of planned to remove the engine since I did transmission work a few ears ago already.
Thanks for any insight.
TLDR: engine is mounted closer to frame on right side. Normal? Issue?
