Pulling barrel and pistons , a Utube recommendation?
Posted: Tue Feb 03, 2015 2:55 am
by Sibbo
My 1981 ST is blowing smoke, not a lot but sufficient for me to want to rememdy the situation .
I'm going to pull the barrels and pistons and take them to my local and very good automotive maching workshop. I'm quite confident the owner will do a good job but I'm less than confident about the removal and replacement.
My Clymer manual is uninspiring so can someone recommend a Youtube video to me ? I dare not choose one myself as I've heard a few of them give very poor advice.
Re: Pulling barrel and pistons , a Utube recommendation?
Posted: Tue Feb 03, 2015 4:26 am
Grant did his for the first time recently, and found it easy enough. He was doing the push rod rubbers.
I think he watched the 3 Chris Harris videos on the subject.
https://www.youtube.com/watch?v=A47LiKSYD9o
Posted: Tue Feb 03, 2015 5:14 am
by Sibbo
Thanks Steve. I really don't know where the smoke is coming from, the bike pulls well, starts well but blows smoke and especially after a run when it's hot .
What are the symptoms of worn push rod rubbers ? Just weeping around the base ?
I'm assuming I need rings .
Posted: Tue Feb 03, 2015 6:53 am
by PAS
How many miles are on the bike? Did you do a compression or leak down test?
Posted: Tue Feb 03, 2015 7:00 am
by Sibbo
80,000 miles . No tests , she starts , runs and goes well but smokes .
Back tomorrow , bed time here.
Posted: Tue Feb 03, 2015 7:48 am
by bbelk
Drips come from Push rod seals, or any other external seam or seal on an airhead. Usually all of them.
Smokes on start up, comes from valve guide seals or sitting on the side stand.
Smokes on deceleration, comes from rings.
I am a "B" grade mechanic and I have done the job on my R90/6 without much guidance and it was pretty straight forward.
Posted: Tue Feb 03, 2015 11:29 am
Don't open it up until you perform the proper tests. Think of it as an autopsy.
Posted: Tue Feb 03, 2015 7:09 pm
by bbelk
Duane Ausherman wrote:Don't open it up until you perform the proper tests.
Park it for a week. If there is a puddle under it, its a drip.
Have someone follow you and either decelerate from high speed in gear or role down a hill at speed with the throttle closed. If it smokes its rings.
If it smokes only on start up, its valve guides. Or possibly an electrical fire if Ken has rebuilt your starter.
Posted: Tue Feb 03, 2015 8:20 pm
by Sibbo
It's rings in that case. Thanks .
Posted: Tue Feb 03, 2015 8:30 pm
Do this test at night, as then the smoke shows up much better. Run it up to a high speed and close the throttle, as suggested.
