Engine Internals to Replace Upon Fresh Rebuild?
Posted: Thu May 05, 2016 3:12 am
Hi, new here, I'm in the process of rebuilding a 1982 r100 engine. It's torn down to the block, (minus the crank, need to make a puller to get the bearing carrier out) and I'm now making a list of parts to buy so I can rebuild it.
The engine will be modified a bit for performance and reliability, and I was wondering, aside from gaskets, seals, stretch bolts, valve lap/guides, Rings... Are there any internal parts that people make a habit of replacing for safety and peace of mind? I.e, bearings, timing chain/tensioner, cam followers, pushrods..? Assuming all the components look fine (visually), which are a good idea to always replace while the engine is apart anyway? Engine will be seeing higher rpm due to the cam.
Some info on what engine will have:
336 cam
dual plugged heads
9.5 Pistons
Oil pan spacer
Keihin FCR flatslides
336 cam
dual plugged heads
9.5 Pistons
Oil pan spacer
