Brake Rod Spring
Posted: Mon May 16, 2016 12:55 am
by KellyVB 75R90S
I was looking at the parts fiche on back brakes at Max BMW and noticed there is a note under the spring that goes on the long rod saying that BMW got rid of it years ago and says not to use it!!! Whats up with that? Has anyone taken it off their /5 and /6 bikes?
Thanks
Kelly
Re: Brake Rod Spring
Posted: Mon May 16, 2016 1:31 am
by Bamboo812
The brake shoe springs are more than sufficient to keep the shoes from dragging. The only purpose that spring would serve that I can see is to keep the brake pedal from bouncing?
Posted: Mon May 16, 2016 8:59 am
by jimmyg
Kelly,
The spring served the purpose of holding the adjustment wing nut in proper position. It isn't needed as the brake springs on the shoes are capable of performing the same function.
If you want 100% originality, then use one, but it isn't needed. I removed mine from my '74 S many, many years ago.
jimmyg
Posted: Mon May 16, 2016 9:54 am
by jagarra
Mine is still on, keeps the pedal from flopping and in the correct position, your foot can't work under the pedal. Most bikes that have a drum rear use them.
Posted: Mon May 16, 2016 6:07 pm
by KellyVB 75R90S
Thanks for the replys guys, I think I will leave it on, doesn't hurt anything.
