Seized Riser Stud
Posted: Wed Jun 01, 2016 9:14 am
So after spending a long time polishing this up to a mirror finish I went to install it with my new top plate and attempted to remove the studs as the new top plate will take special machined socket caps.
Three of the studs came out fine and I noticed some genius replaced one of them with a regular construction bolt that must have a slightly different thread pitch. Either that or they didn't apply any copper anti-seize.
I've tried removing it with the two bolt technique, tried torching the riser and freeze spraying the stud... Even let it soak overnight in an ATF-70/Acetone-30 mix. Nada
Is there something else I should try? Or pick a new one up for $25 I found on eBay?
