73 r75/5 battery height
sprints@pldi.net
Post by sprints@pldi.net »
I looked through several of my manuals but can't find the height of the stock battery. The battery in my bike fit well in width and length but was too high by about 1/2" for the tool box tray to fit.
Let me know what the stock height should be and perhaps were you found the info so I'll have another source. Then I can go shopping for a new battery, hopefully a sealed unit - Rod
sprints@pldi.net
Re: 73 r75/5 battery height
Max BMW shows this sealed battery as correct, and the dimensions are 195mm x 85mm x 175mm - 7x7x3" (their conversion, not mine)
PN: 61212346800
http://www.maxbmwmotorcycles.com/fiche/ ... 6%20800%0A
The fiche shows this lead acid (PN: 61210403224) with the dimensions 181mm x 78mm x 170mm
http://www.maxbmwmotorcycles.com/fiche/ ... am=61_0212
Course, I don't suppose you could have just measured your current battery and subtracted the amount necessary to fit.... ;)
equipo5
Post by equipo5 »
Me Too!
I have a motobatt battery 171mm high but it is still 5mm too high.
1970 R75/5
Bamboo812
Post by Bamboo812 »
Odyssey PC680 will work.
Deka. As good as the others.
http://www.euromotoelectrics.com/Batter ... etx14l.htm
150w x145h x88d. 220cca.
I thought the short wheelbase /5's used the same 18Ah battery as an R65. The one I've got is 181 W x 167 H x 77 D
That 's a commonly available size in generic AGM and Gel batteries.
