project r90/6 wont start -- help needed
Ken in Oklahoma
Re: project r90/6 wont start -- help needed
Post by Ken in Oklahoma »
George Ryals wrote:Wire and guitar strings can be made to work, but the Cadillac of carb jet cleaning is a set of Carb jet reamers: google it.
They do look like dandies. I was interested to note, on the pic I pulled up, that the ends were ground to a point, as opposed to the rounded ends I sort of try to achieve. I guess something like a point would be appropriate. The 'sharp' point would always be held away from the wall of the tunnel. It would be the edges of the 'reamer' that would need to be relieved. Or so I think.
To me the term 'reamer' is a bit disturbing, as it would seem to imply removing material. I think of my guitar string 'reamers' more as 'pushers' simply disturbing crud that is softer than the surrounding soft zinc or zinc like metal. Once disturbed cleaning fluid can flow and melt the rest of the curd away.
As an aside I shudder at carb cleaners where you dunk the carb into a nasty broth for a period of time. I'm sure there are warnings on the label saying not to leave the carb immersed for an extended period of time. I have in my possession a set of 32mm flat top Bings with a plastic side plate. Evidently the carbs were immersed in such a cleaner so long that the plastic started to melt. As I recall the carbs came from a parts R80/7 that I acquired that shows lots of signs of abuse, or perhaps more accurately, idiocy.
Ken in Oklahoma wrote: I think of my guitar string 'reamers' more as 'pushers' simply disturbing crud that is softer than the surrounding soft zinc or zinc like metal. Once disturbed cleaning fluid can flow and melt the rest of the curd away.
Cool typo. Carbs are certainly not the only mechanical part I've ever struggled to clean all the crud curds out of. ;)
pleather717
Post by pleather717 »
extended stay in carb cleaner dip and a good amount of compressed air did the trick, will be ready try and start the bike again soon... fingers crossed
Porge
Post by Porge »
Pleather,
I presume you've taken the jets out so you can "sight" through them?
Andrew, Launceston, Tasmania, Australia
_____________________
1956 Matchless G80S
1975 BMW R75/6
1978 Yamaha SR500
1982 Honda Z50R
2002 Honda CT110 Postie
One must have very good eyes, or a glass for that inspection. I small 20% occlusion can cause trouble with tuning. Don't ask.
George Ryals
Post by George Ryals »
With the Jet reamer/cleaner, you pick a reamer/cleaner exactly the size of the passageway/orifice so the reamer/cleaner scrapes the film of goo out and removes no metal. You can increase jet sizes if you want to.
Jets can appear to be clear but have a .002" thick film effectively changing the jet size.
Smile it's contagious!
'85 R80RT wreck for parts
pleather717
Re: project r90/6 wont start -- UPDATE -- IT RUNS!!
SHE RUNS!!! MY GARAGE IS SMOKIER THAN A BBQ RESTAURANT... YAY!!
cleaning the carbs again certainly helped as one jet was def. clogged.
set float level to proper height, installed new green dyna coil.
WHAMMO!!! it coughed to life in an instant -- starts, runs, choke works!!
it leaks oil from 2 places and is burning off 20+ years of oil and other fluids on the exhaust. i am missing left muffler and still a TON of work to do but this is fantastic.
thanks for all of your tips everybody !! new coil certainly provided a much fatter spark
paul
grant81rs
Post by grant81rs »
Gidday,
Well Done !! :D
Cheers, Grant
Gippsland - Australia
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
Porge
Post by Porge »
Onya!
1956 Matchless G80S
1975 BMW R75/6
1978 Yamaha SR500
1982 Honda Z50R
