First post from a new airhead owner.
Recently picked up a 1976 R75/6 in pretty decent condition. Rebuilt the carbs, and she was running quite well!
Yesterday, I was out for a ride. Parked the bike, met some friends, then went to start it up about 30 min later. Turn the key: no power, no lights, no dash lights, no power period. Turn the key again: power. Okayyy, start and drive 25 feet.. put put die: no power!
I did some roadside checks: battery terminals tight and in good shape. Battery ground tight and in good shape. Next I pull apart the headlight to gain access to the ignition switch and circuitry. Check the connectors on the ignition barrel, everything seems tight and okay. Try switching the 30 Amp red wire on the circuit board to the auxiliary 30 Amp circuit, no result. (The bike is new to me, and I am not very familiar with it as of yet. I assume the extra 30 amp terminals on the circuit board behind the headlight are auxiliary circuits, and you can simply switch between the two?)
Next I disconnect the wires from the ignition barrel, and try to jump the red power wire to the others (just touching the wires together), in turn, to see if I get power. Presto! Red to single green gives me lights, and red to the double green wire gives me signal lights, and power to the ignition.
This means, to me, that all relays and associated things on the circuit are working fine, it is simply a faulty ignition switch. Does my logic check out?
And.. what all of this leads me to asking: is it possible to take apart the ignition barrel and check/repair the internal contacts?
I did not seem obvious that the ignition barrel will come apart.. but I am hoping that it will. Please, experienced ones, bless me with your r75 knowledge
Thanks a lot guys!
Stu
