Drive shaft lub quantity?
Sibbo
Post by Sibbo »
Can someone tell me how much oil goes into my R80 ST drive shaft tube ? The Haynes manual doesn't tell me ... I know it's a piece of crap.
I seem to remember 150ml ?
The Grateful Dead
Bamboo812
Re: Drive shaft lub quantity?
Post by Bamboo812 »
yep
Duane has often said that you can get by with even less, probably as little as 50cc. But certainly anything in the 100cc range would be more than enough. Less volume taken up by the fluid means less of a chance to over pressurize the inside of the tube.
See posts on these pages:
viewtopic.php?f=1&t=3987
viewtopic.php?f=1&t=3867
Sibbo
Post by Sibbo »
Thank you.
The Grateful Dead
150 is the spec but I never use more than 120 on the grounds that you never get all the old oil out and If I put in too much it ends up migrating to the final drive.
