Thinking of branching out.
- Zombie Master
Re: Thinking of branching out.
Congratz on the KLR! Make sure if the dohickey has been replaced it was done properly. Fellow I know just had one wreck his engine due to a poor installation.
Advert has gone. Presumed sold.SteveD wrote:Looked at a R100GS tonight, 'cause it was only 30 min away. $5K asking.
Probably needed... push rod seals x 4, left head gasket, sump gasket, new tyres for rwc. I'm guessing $1500 to get it up to snuff which includes rego.
Still looking.
Todays considerations.
$10.6K, 32K kms. Too many $.
$8.4K, 52K kms. Grant likes this one.
2001 R1100S $5.5K, 63K kms. Might be around $5K as the seller would need to take the day off to get a rwc..which I could get easy enough. It's a big day out to go and see.
1/2005 K1200S, 52.6K km, asking $6990. Full service history, last service @ $1800 included new tyres, final drive recall update & a minor service, done by local blokes I know. 6 mths rego. Timing chain update done. NO panniers. Some negotiation probable. Local to me. Looks fine...except the yellow!
Then there's the issue of servo assisted linked abs. It has a reputation for failure and a $3500 replacement cost.
- Sibbo
Black and yellow looks best on a GS.
The Grateful Dead
The Grateful Dead
More info. The abs up to '06 can cost >$3K to fix if it fails. It's an internal fault not related to poor fluid maintenance. If it fails brakes are lost..can't be turned off. Apparently this is a big cause of crashing, but BMW turn away from the issue. The system was updated after 2006 I believe.
The 60K km service for a K1200s is $1000 or so, every 30K km. I'm guessing I can do a lot of the peripheral stuff myself, but the valves might be beyond me, well it would be now, maybe not with some lurnin'.
Gidday,
Black and yellow is nice Steve, plus another "K" into the group
Cheers, Grant
Gippsland - Australia
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
- Sibbo
Is that all models Steve or just Ks ?SteveD wrote:More info. The abs up to '06 can cost >$3K to fix if it fails. It's an internal fault not related to poor fluid maintenance. If it fails brakes are lost..can't be turned off. Apparently this is a big cause of crashing, but BMW turn away from the issue. The system was updated after 2006 I believe.
The Grateful Dead
The Grateful Dead
I think it's any servo assisted linked abs up to 2007. I would stand corrected. I'm still investigating.
- Sibbo
Displaying ignorance ....would it apply to the G series 650s ?
The Grateful Dead
The Grateful Dead
