valve spring too tight
mushroommark
Post by mushroommark »
helloooo,,,was adjusting my valve clearance...every 4ooo k and my right ,,,exhast is un adjustable ,,like the spring is farther out than it should be 81 r100....whut up withthat? thanks!!
:shock:
Re: valve spring too tight
Are you sure you're at TDC on the compression stroke when adjusting the valves? You really didn't say what you've been doing, but you typically find TDC on the compression stroke for say the left side, then set the valves. Rotate the engine 360 degree to the next TDC and then set the right valves.
Can you link in some pictures showing the situation with the rocker arm adjusters?
mushroommark
i hearya...i usually use apiece of woodinthe spark plug hole,,to find tdc,,as my marks are all wrong,,,but no matter where i spin the engine she just w ont loosen up...aaarrrrrit
got it running...bit tight,,forsure...intake right is fine,,left side all good
mushroommark
no can do photo gotta get to werk,,,put er back together
Just finding TDC is only half the issue...it must be on the compression stroke, that is the intake just closed while rotating the engine and then the very next TDC that shows up is "on the compression stroke."
I don't see how a spring could be "too tight" unless you've lost the keepers at the end of the valve...but the engine would run for crap. You have an '81 R100 which could be experiencing valve face plastic deformation. The '81-84 models (especially the 1000cc ones) were prone to this due to poor heat conducting valve seats. How many miles are on this engine?
mushroommark
Thanks for the feedback Kurt. :D
will unbuckle and do a video tommorrow..should be funny!
something might be bent...aaaahhh..........pulled the rods straight...may have to go deeper.
abligato!
Has the adjuster run out of threads for proper adjustment?
If the spring is too tight, then you will see that there is no room between turns. It would be smashed together. I have never seen this happen, so I think that it is something else.
jagarra
Post by jagarra »
If you back off the adjuster on the rocker and there is no clearance then it looks like the spring is not being retrained by the keeper. Either the keeper failed as previously mentioned or the cup on the valve spring under the keeper broke. I would pull the rocker assemblies and have a good look see at the tops of the springs.
1974 R90/6 built 9/73
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
George Ryals
Post by George Ryals »
Measure the installed height of the spring. If it is significantly higher than the other exhaust valve, the valve is sinking into the head and becoming taller and taller running you out of adjustment on the rocker arm. Maybe???
Smile it's contagious!
'85 R80RT wreck for parts
jimmyg
Post by jimmyg »
Be absolutely certain you are rotating the engine clockwise when viewed from the front. Don't ask how I know this. :(
jimmyg
