ATE Brake - What is this part/piece?
I'm rebuilding my calipers and was wondering if anyone knows what this is... it looks like a threaded stud but it isn't visible when looking inside the caliper reservoir.
Re: ATE Brake - What is this part/piece?
I think that's just a hard rubber buffer whose purpose is to immobilise the caliper between the two "ears" of the fixed part of the caliper. Without them (there should be one on the other side, as well), the swinging part of the caliper will move along with the brake disk when you apply the brakes. I've found them glued into the shallow hole they sit in, but I'm not sure if it was a "press fit" originally.
I think it is a scuff pad to protect the ears on the forks. Sort of protects from metal to metal contact as the caliper moves sideways.
1974 R90/6 built 9/73
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
- Ken in Oklahoma
Me too.jagarra wrote:I think it is a scuff pad to protect the ears on the forks. Sort of protects from metal to metal contact as the caliper moves sideways.
Probably protects but in the way it also lets the caliper slide easier...imagine if it was metal to metal...that wouldn't slide at all.
Great thanks everyone. So here's what these 38 year old ATE calipers look like after a complete rebuild and a bit of polishing. They are so shiny my wife pulled out her lipstick to see if she could put on makeup looking at them and joked that if they weren't so heavy she'd keep one in her purse.
My brother by another mother! I've done that, too:
I figured I could use it as a campground shaving mirror.
