Accessory Jack dead
Accessory Jack dead
Hello all, does any one know if there is a separate fuse for the accessory jack under the battery? My bike is a 94 R100R.
Re: Accessory Jack dead
I have the same bike (94 Mystic).
Under the left side cover (with the cutout for the lift handle), there is a fuse holder with 4 fuses.
The second from the rear supplies power to the accessory plug. 15A
Thanks Seth!! I will check that. I figure it is most likely the problem. I wanted to use a GPS and discovered no power there...
