http://cgi.ebay.com/ebaymotors/BMW-Luft ... 4418580997
Not mine!
Luftmeister Auxiliary Fuel Tanks on eBay
Re: Luftmeister Auxiliary Fuel Tanks on eBay
A good link in that auction, too, regarding care and feeding of those things.
Deleted User 61
Wow - I had never heard of them being made for Type-248's. (Not that they did)vanzen@rockerboxer.com wrote:A good link in that auction, too, regarding care and feeding of those things.
Learn a new 30 year-old rumor every day! (Well, not every day.)
dwerbil
- Moderator
All good except I'd totally would not use his hook-up directions, you'd end up with a whopping tonnage of possible leak points using all those tee's. My set up uses only two tees...vanzen@rockerboxer.com wrote:A good link in that auction, too, regarding care and feeding of those things.
Main tank left petcock line go straight to the upper inlets of the left Luft tank; same for the right. Each bottom Luft petcock lines go directly to it's corresponding carb inlet. INBETWEEN the bottom lines, put in two tee's to make the cross-over.
And that's all the tanks need for hook up. The above has about half the fuel line connections as Snowbums.
dwerbil
- Moderator
Sold for 200 smackers. Has the high price ebay days for the Lufties run out of gas? It looks like it did at least for this seller's set.
