This looks like the sort of person who would have no trouble popping out a 120º V twin BMW motor...
V twin BMW
Re: V twin BMW
Brilliant! any links?
New to the forum, but returning BMW owner. (R75/5 1970, R75/7 1977, to K1 in 1989). Not new to making, fixing, or modifying stuff in metal or plastic. Don't need to be taught how to suck eggs, but if you've got a new way, I'm interested
the quinner
Re: V twin BMW
Fallert made a bevel drive "V twin" BMW that was something like a 176* or 178* "V"...it looked like a flat twin, but technically was a (very)wide V.
edit...I was wrong...here's the story from "BMW Racing Motorcycles the Mastery of Speed" by Laurel C.Allen and Mark Gardiner...
"...handful of machines built by Werner Fallert. Fallert's frame was a more conventional-looking unit, but his motors eschewed almost all factory components. Taking little more than inspiration from an R100RS motor, Fallert converted it from a two-valve-per-cylinder OHV design to a four-valve overhead cam unit. Like the old works racers, his cams were bevel-driven. Where Krauser and many others had improved ground clearance by raising the motor, shortening the cylinders, and chamfering the valve covers, Fallert actually changed the cylinder axes, turning the motor into a 170-degree shallow vee..."
Re: V twin BMW
3 cams?Native /5 wrote:Did it look like this?chasbmw wrote:I ha seen pics of a three cylinder BMW engine, mounted on the front of a Morgan type 3 wheeler.
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
- enigmaT120
Re: V twin BMW
A long time ago I read an article in The Classic Motorcycle about a guy who converted a flat twin into a V twin, but I thought he started with a Douglas. I didn't see the point but was impressed with his fabrication skills. With all of the work involved I don't understand why he didn't just make a motor from scratch, if that's what he wanted.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
'81 R65
'70 Bonneville
Falls City, OR
Re: V twin BMW
Someone made a Douglas flat 4 with the cylinders stacked. Only 2 carbs with very convoluted carb plumbing, I'll dig out some pics, looked very well made, but have not heard it running
Re: V twin BMW
Didn't Brough build some thing like that once?chasbmw wrote:Someone made a Douglas flat 4 with the cylinders stacked. Only 2 carbs with very convoluted carb plumbing, I'll dig out some pics, looked very well made, but have not heard it running
