Here's my take on it: cooling is all about surface area, is the surface area is increased by drilling, then it should work. In this case, however, the holes reduce the amount of metal transferring heat to the outer edge of the fin, so I think not. Also, for a given thickness of fin, the larger the hole the less surface area produced, making me think that a series of smaller holes, say for example the same diameter as the thickness of the fins, would be more effective...mattcfish wrote:Drilling the fins was an old mod I've seen on some vintage racers. It was supposed to improve cooling. Any opinions on that?Tim Shepherd wrote:I would tend to agree:mattcfish wrote:
I this case, someone needs to take away his drill.
Modified BMWs
Deleted User 62
Re: Modified BMWs
Deleted User 287
Re: Modified BMWs
Me too.Tim Shepherd wrote:Made me look, ya did, and sure enough... one on both sides (R75/5)the quinner wrote:Vanzen's info is true for the 1977 and later blocks...some of the earlier blocks had a drain hole on the right side (rider's right...the non-dipstick side).vanzen@rockerboxer.com wrote:The other side of the "block" contains an "oil condensing chamber"
located to the left of the starter when viewing the engine from the front.
Holes drilled there, without further crank-breather plumbing considerations,
might actually resolve the "stuck breather" scenario that Kurt anticipated.
The only "drain hole" is on the dip-stick side ...
Type-248 - I have a '80 and '81 - both have two holes.
Looking at some pictures of the bike with the original '79 engine, it did too.
That is what my original statement was based on.
Re: Modified BMWs
Appreciate the information.justoneoftheguys wrote:That is what my original statement was based on.
OK – the oldest bike in my garage is a 78 R100/7.
(the 52 in the living room has neither drain holes nor a starter)
Which leaves me curious ... a question, then:
Do these pre-77 and Type-248 engines have an "oil condensing chamber" as the later cases ?
Deleted User 287
the quinner
Re: Modified BMWs
No. The earliest breathers dumped straight back into the air stream of the right carb tube. At some point, they updated the assembly (breather cover and hose) to exit up then back. Rob's photo looks like the updated parts.vanzen@rockerboxer.com wrote:Which leaves me curious ... a question, then:
Deleted User 287
Re: Modified BMWs
The earliest R65's had the breather hose that went into a 'T' to dump into both intake tubes.the quinner wrote:No. The earliest breathers dumped straight back into the air stream of the right carb tube. At some point, they updated the assembly (breather cover and hose) to exit up then back. Rob's photo looks like the updated parts.vanzen@rockerboxer.com wrote:Which leaves me curious ... a question, then:
Re: Modified BMWs
Yes they do. The breather cover is different. This is the best pic I have and only shows cover.vanzen@rockerboxer.com wrote:
But what is underneath is roughly the same as a 248.
Re: Modified BMWs
Thanks again, Rob –justoneoftheguys wrote: I'm not sure. You are not talking about the crankcase breather, are you? This is the 1980 block:
By your photo, I see that there is no condensing chamber as it exists on the later Type-247.
The oil condensing chamber of post-1977 Type-247s
extends the length of the starter housing and precludes a drain hole on that side.
#21 in this pic:
Deleted User 287
Re: Modified BMWs
Thanks for the further clarification, vanzen.
So the condensing chamber is companion to the blocks that have the crankcase vent located at the front?
