/5 center stand bushing installation
x1Buellist
Post by x1Buellist »
I installed a new center stand today and am not sure it is installed correctly. It does work correctly but the bushings did not install the way I thought they would. The way it is installed, the bushings are bolted to the frame like a spacer. The bushings dont move. I thought the centerstand and bushing would move together. The way it is now there is no way to really grease it because the center stand flange moving around the bushing leaves no place to apply grease or atleast no place where the grease will last a while. What do you think?
73' R75/5 LWB
the quinner
Re: /5 center stand bushing installation
Post by the quinner »
For that application, I use PJ-1 Black Label Chain Lube. It's a tacky moly grease w/ a solvent carrier in a spray can with a straw...
Place the bike on the sidestand (that is, unload the centerstand). Spray the PJ-1 while wigging the centerstand. The solvent allows the chain lube to creep into recesses and hard to reach areas. Wipe away the excess. The solvent will evaporate...leaving the tacky grease behind...
Great for cable ends, too. One of the small cans will last a LONG time
Your installation is correct the bushings are not supposed to rotate. In fact the real damage to the frame lugs occurs when they come loose. My solution to long life is routine removal, clean and re-grease perhaps once a year or every few years depending on use.
http://www.bmwscotter.org/procedures/ce ... ervice.htm
x1Buellist
barryh wrote:Your installation is correct the bushings are not supposed to rotate. In fact the real damage to the frame lugs occurs when they come loose. My solution to long life is routine removal, clean and re-grease perhaps once a year or every few years depending on use.
Thanks, this link you provided is exactly the information I was hoping to find.
73' R75/5 LWB
Post by Chuey »
Wow! That page of info is the best written and most complete information I've come across. I'm going to try to find more of the pages. I am super impressed.
Deleted User 62
Post by Deleted User 62 »
Here you go, Chuey: http://www.bmwscotter.org
Thanks Barry and Tim for the BMWSCOTTER links. That is a valuable resource for /5 and /6 fettlin'. Very crisp technical writing and excellent use of images. I've put a shortcut on my desktop so I can enjoy at my leisure.
