After almost 3 months I got a Nikasil cylinder and piston for the 92 R100GS, with the set of head I purchased in June, I have all the major parts I need to get the bike back on the road.
You do not see many R100 Nikasil cylinders on the market.
Here is a good read in ADVRider on dropped valves.
http://www.advrider.com/forums/showthread.php?t=609330
Got Parts
Armaguidon13
Re: Got Parts
I've had the exact same "joke" with my G/S
Now the first think I buy with a new air head is BMW valves...
Re: Got Parts
I think the probability of dropping a valve increases exponentially as the guide wears out and gets looser..
If the guide is loose, the valve doesn't slam squarely into the seat each time it closes.
I replace my guides BEFORE it starts to burn oil.
Exhaust guides always become loose enough to warrant replacing between 100,000 -160,000kms.
- enigmaT120
Re: Got Parts
Do you change them based on miles, or are there symptoms you look for besides smoke?
Edit: Distance, not miles. Sorry Mr. Metric.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
'81 R65
'70 Bonneville
Falls City, OR
Re: Got Parts
The inside of my valve covers and rocker area is as clean as the outside, looks brand new.enigmaT120 wrote:Do you change them based on miles, or are there symptoms you look for besides smoke?
I clean it all spotlessly each time I check my valves (5000kms?)
When I start to see brown discoloration regularly re-occurring on the exhaust side,
I know the newness is gone and the end is slowly approaching.
If you catch them before they are shot, the valves and seats will just need a bit of lapping.
The guides are only around $20ea, no big deal.
The cost of refreshing a head greatly diminishes if you do it BEFORE the valves NEED replacing and the seats NEED re-cutting or replacing. (I do not cut valves, I replace them).
Armaguidon13
Re: Got Parts
Broken valve at low city speed nothing to help me to understand a danger for the engine, no noise, nothing. This bike wasn't an oil burner
