8500rpm !
So ,how do they do that ????
- Sibbo
The Grateful Dead
The Grateful Dead
Re: So ,how do they do that ????
Well... first you git yerself a big ol' shovel, and then you find a bigger pile of $$$$$$$, and then.....
...and then you ride it!!! (but don't bother, the shipping from Japan would probably kill you)
- Sibbo
I could just buy a Ducati ,but they don't look as good .Good but not as good .
The Grateful Dead
The Grateful Dead
So why the different rocker covers???
- Sibbo
Faster ?
The Grateful Dead
The Grateful Dead
So, how's about the color of those pipes? Maybe they're titanium.
To answer you first question; it has those exotic slide carbs, probably the later/lighter clutch carrier, hot cams no doubt, and most likely a lightened valve train, etc etc. Any slide carb setup should speed up throttle response, it's like putting a mechanical advance distributor in a car that had vacuum advance.Sibbo wrote:
8500rpm !![]()
The cheapest way I found to get a rev response like that, is to take the clutch and gearbox off
- Sibbo
What is this carb ? I don't recognise it .
The Grateful Dead
The Grateful Dead
Keihin I think.
