The story started here: http://boxerworks.com/forum2/viewtopic. ... 876#p51876
The short version: The engine stopped while I was riding. There was spark at the plugs but it wouldn't fire at all. The coil appeared to test as faulty but it turns out that you test dual output coils differently to how you test your standard car coil. The new coil (Dyna brown) tests almost identically to the old coil give or take a few ohms.
I put the new coil in and the bike started first go and is running really well....now. Not at first.
Before I broke down I noticed that the bike was bogging down badly when accelerating from 5,000 revs in top. I had put this down as a symptom of whatever it was that made me break down. The same thing still happened with the new coil.
I believe that a hole in the diaphragm will cause this sort of problem so they were the first suspects. As I has just replaced them I thought that perhaps I had installed one badly. But as the bike was otherwise running well ( and I didn't have time to pull the carbies apart) I just kept riding it and, after a few hundred kilometres, it fixed itself.
I think it was probably some grit on the slide that worked itself loose. But I may never know.
The lesson in this (one of many) is: don't get obsessed with fixing what you think is wrong; you may have more than one problem.
Cheers and thanks for all the help,
Ray
The end of the coil story and a lesson for all of us.
1986 BMW R65
2008 Moto Guzzi Breva 750
2019 Kawasaki Z900rs
Re: The end of the coil story and a lesson for all of us.
Ah, well, at least it's a happy ending.
- enigmaT120
Things like that make me paranoid for a long time.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
'81 R65
'70 Bonneville
Falls City, OR
But......the lesson is.......you still don't know what the problem was...and still could be.
Maybe just water in the gas? I had that happen before. Easy to see in the float bowl.
I believe the lesson is: Airheads don't fix themselvesmattcfish wrote:But......the lesson is.......you still don't know what the problem was...and still could be.
...except when they do.
That's a fair point - I don't really know what happened. But I would be keen to hear suggestions so that if it happens again I know where to start looking.mattcfish wrote:But......the lesson is.......you still don't know what the problem was...and still could be.
It probably wasn't water in the petrol as I'd had the float bowls off and all was fine. I did wonder if it could have been a bad tank of petrol. I filled up about 120km before I broke down and I don't recall the bike acting up before that. But wouldn't that problem be solved instantly when I filled up again? The issue seemed to fade away over several hundred kms rather than cease quickly.
1986 BMW R65
If it's "fixed itself" then my money would be on a fuel issue that's cleared.
A few years back I ended up at 2valves place in Glen Innes with a problem vaguely similar to yours.
The bike wouldn't run well at higher rpm and under load up a hill was a disaster, but if I backed off and took it quietly it would literally limp up the hill.
Between 2valves and me we couldn't resolve it. I had a go in the evening at all the usual suspects, and we both had another look see the following morning. A call to my local mechanics at BM Motorcycles in Ringwood, Melbourne had them suggesting everything we'd already done too. At least we were on the right track. Then the last suggestion...check the main jets.
Bingo. A solid piece of fuel hose had blocked the left main. Problem solved. Shame I didn't check it first.
I am never happy when something "fixes itself" and have seen it plenty of times. It usually returns to bite one in the a$$ when least expected.
Riding would be a bit uncomfortable in that I would keep trying to find more symptoms returning.
Good point. Old rubber fuel lines desolve over time and leave goo in your carbs. Use modern Polyurethane hose and the problem is no more. http://www.aircraftspruce.com/catalog/a ... elline.php. Bing has it too.SteveD wrote:If it's "fixed itself" then my money would be on a fuel issue that's cleared.
Some of the hose material may not fall apart, but it can harden badly and then leak.
