I've recently picked up a 74' R90S in bits and am in the process of putting it back together. It's a slow process as every part has to be located in the boxes and then checked to make sure its good. There are a heap of spares with the bike and it's often hard to figure out which part is the original. This process is made harder still by the original owner (who I've never met or spoken too) having brought or sourced a heap of aftermarket or performance parts and then chucking them in with the standard bits.
At the moment I'm trying to figure out which of the two available cams to use. The best I can do is measure lift and take pictures.
Here's the two side by side
Here's the lift numbers
The cam marked 921 measured 6.75mm lift on all four lobes, x1.39 = 9.3825mm or 0.3693"
The cam marked 630 measured 7.64 lift or near enough on all the lobes, x1.39 = 10.6196mm or 0.4180"
If anyone's got any idea what either of these two are I'd love to know.
Cheers
Sam
