I quick teaser to end the year on fellas..
I have a leaking push rod tube seal on the right side, this I knew about from the PO when I brought the bike as it was about the only thing he said needed doing before this bike could be ridden around Australia as it was
So I have watched the 3 x part Youtube videos on push rod tube seal replacements from Chris Harris at affordable beemer services who is now called Team Monkey Productions btw, the vids I have studied a few times to get me in the groove to do the repair when the parts arrive.
My bike is a 1978 R100RS and my question is regards to a base gasket at the crankcase /cylinder head and do I or don't I use/replace them as the RealOEM site does not list any for that year but does list a gasket sealant only?
Also on the Chris Harris vids I did not see any base gasket come off or go on, only a new O-ring being replace and new head gasket and nothing was mentioned about base gasket that I remember, but on the Motorworks new parts site it does list base gaskets for all r100's.
I was a little confused, so I just brought all the new parts for the job, plus the gasket sealant but minus the new base gaskets
Can someone advice if I am wrong or explain the pro and cons of no base gasket etc or yes they are recommended!!
Thanks for any info received
