Here's a video from Edelweiss Motorsport of a modified R80 producing over 90 hp! https://de-de.facebook.com/edelweissmotorsport "Details:
it is our 98 mm / 1070ccm bbk with a working squish.
It is not a bolt on solution, the head must be machined to fit the piston.
Valve seats and ports are optimised, valves 44/40 - 45 deg.
Our asymmetrical cam EM2V1 latest spec for low end and mid range promotion.
Light cam followers and tapered push rods.
Free programmable double ignition.
That's it.
Best reg.
Dirk "
Dyno Work
Re: Dyno Work
Oil pumps take HP, so they did away with it.
Re: Dyno Work
What do they put in the printer?Rob wrote:3D laser-printed oil.
Re: Dyno Work
$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$Duane Ausherman wrote:What do they put in the printer?Rob wrote:3D laser-printed oil.
