No Nut!
No Nut!
I can't figure out how to remove the drive shaft from the (small tube/solid shaft) swing arm. I have the Cycleworks tool and it says there is supposed to be a nut on the "cup" end of the shaft. There is no snap ring visible and I can't figure out how to get this suckah apart. Is this an unusual set-up?
Thanks for any help.
enigmaT120
Re: No Nut!
Post by enigmaT120 »
What bike? Maybe it goes out the other end. I've never bothered to remove the one from my R65 but on my friend's '93 R100 GSPD it pulls to the front right out of the final drive.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
Re: No Nut!
I have never seen that set-up. Probably well after my time. Most things today are.
Re: No Nut!
The photograph actually looks like there IS an external snap ring visible.
Re: No Nut!
Post by Rob »
Major Softie wrote:The photograph actually looks like there IS an external snap ring visible.
I couldn't see it, but if there is a cush spring, and ramps in there, than you will have to compress the spring and pick out the snap ring.
It would help to know the year of the assembly.
Bamboo812
Re: No Nut!
Post by Bamboo812 »
Cush drive Mono Shock? There's a snap ring: Image
Re: No Nut!
Post by Rob »
Bamboo812 wrote:Cush drive Mono Shock? There's a snap ring:
Is it a mono-shock?
Has Chuey shared some details with you privately?
The R65 had the cush drive, that is how I knew about it. But I am pretty sure Chuey doesn't have a R65.
Bamboo812
Re: No Nut!
Post by Bamboo812 »
Is it a mono-shock?
Nah, just a wild guess, and the first drive shaft with no nut I could find on Max. What year did the R65 get cush drive?
Re: No Nut!
I see a snap ring. The open part is between 10-12 O'clock. Just zoom in on the photo.
Re: No Nut!
Post by Rob »
Bamboo812 wrote:
Is it a mono-shock?
'78 for Europe, '79 for NA,
