Bad Headshake at 40MPH
I had to bring "Mr. Thirsty" (my Dodge truck) to work this morning. My bike developed almost a "tank slapper" at about 40MPH this morning. This has been getting worse for a while now, and I attribute this to my fork seals leaking, and an imbalance of fluid. Hopefully the seals I ordered last week should be in the mail today so I can do the job over the weekend.
AMA Charter Life Member
Re: Bad Headshake at 40MPH
The first place I would look is at the front tire. It doesn't take much non-uniformity in the tire to do this. I think forks can do it, but I have gone quite aways on bikes with leaky seals without getting into the problem.
1979 R65
1979 R65
Adjust steering head bearings.
Thanks, but my tires are Pirelli Sport Demons, and are fine. I am more suspect to steering head bearings, which I will check when I am installing my fork seals. I will also check and lubricate my wheel bearings while things are apart.
Worn tyres, tyre pressure too low, head stem bearings, wheel bearings, loose axle nut, overloaded, right caliper was hanging up
...sometimes it's a process of elimination. Some are easier, quicker and cheaper than others to fix. I hope you get lucky.
My right caliper was hanging up, so problem solved!!
