/5 Sidestand
Posted: Sun Jun 19, 2016 10:24 am
I checked Duane's site first! I removed the two into one exhaust on my '71. After installing the proper exhaust system my side stand would not retract all the way because someone welded additional round stock to the inside curve of the OEM stand. I ground the welds off and removed the stock. I'd like to remove, replace and or repair the side stand. It appears someone also welded the top of the pivot pin of the stand. Was that pivot supposed to screw out or is it a part of the entire assembly? Which is welded to the frame. Either a picture or explanation is what I'm looking for.
