Helpful Hints
bbelk
Helpful Hints
Post by bbelk »
If you pour 500ML of 140 wt gear oil down the side of your motorcycle lift and onto the wooden shop floor in 40 degree weather it is VERY hard to clean up.
The secrete is a harbor freight heat gun! Within seconds, a three inch circle liquifies and can be dobbed up with a rag. Works on metal or wood. Repeat until it quits beading up.
1975 R90/6
1979 R65
Re: Helpful Hints
bbelk wrote:If you pour 500ML of 140 wt gear oil down the side of your motorcycle lift and onto the wooden shop floor in 40 degree weather it is VERY hard to clean up.
I'm very sorry to hear you secrete gear oil. :o
bbelk
Re: Helpful Hints
Post by bbelk »
Major Softie wrote:I'm very sorry to hear you secrete gear oil. :o
Harumph..
1975 R90/6
1979 R65
Re: Helpful Hints
Post by Garnet »
What kinda gear oil do you use in a headlight relay? :?
dougie
Re: Helpful Hints
Post by dougie »
Garnet wrote:What kinda gear oil do you use in a headlight relay? :?
"Light" weight oil silly. :roll:
Deleted User 287
Re: Helpful Hints
Post by Deleted User 287 »
Hey MS, shouldn't there be a comma after 'oil' and before 'silly'? :lol:
Re: Helpful Hints
Why, yes there should. BUT, I would never be so petty as to point that out myself.... :mrgreen:
Re: Helpful Hints
Hey MS, shouldn't there be a comma after 'oil' and before 'silly'? :lol:[/quote]
Why, yes there should. BUT, I would never be so petty as to point that out myself.... :mrgreen:[/quote]
Re: Helpful Hints
Good tip. I'm sure my Crappy Tire (Canadian Tire) one would work just as well, and be nearly as cheapo!
Do check for hidden oil on your lift. It can sneak up on you. Give it a thorough inspection! :ugeek:
Re: Helpful Hints
From MS, "Why, yes there should. BUT, I would never be so petty as to point that out myself.... "
Notice how cleverly he turned it around so deftly? Shheeesh.
