If you pour 500ML of 140 wt gear oil down the side of your motorcycle lift and onto the wooden shop floor in 40 degree weather it is VERY hard to clean up.
The secrete is a harbor freight heat gun! Within seconds, a three inch circle liquifies and can be dobbed up with a rag. Works on metal or wood. Repeat until it quits beading up.
Helpful Hints
Re: Helpful Hints
I'm very sorry to hear you secrete gear oil.bbelk wrote:If you pour 500ML of 140 wt gear oil down the side of your motorcycle lift and onto the wooden shop floor in 40 degree weather it is VERY hard to clean up.
Re: Helpful Hints
Harumph..Major Softie wrote:I'm very sorry to hear you secrete gear oil.
1975 R90/6
1979 R65
1979 R65
Re: Helpful Hints
"Light" weight oil silly.Garnet wrote:What kinda gear oil do you use in a headlight relay?
Deleted User 287
Re: Helpful Hints
Hey MS, shouldn't there be a comma after 'oil' and before 'silly'?dougie wrote:"Light" weight oil silly.Garnet wrote:What kinda gear oil do you use in a headlight relay?
Re: Helpful Hints
Why, yes there should. BUT, I would never be so petty as to point that out myself....justoneoftheguys wrote:Hey MS, shouldn't there be a comma after 'oil' and before 'silly'?dougie wrote:"Light" weight oil silly.Garnet wrote:What kinda gear oil do you use in a headlight relay?
- Zombie Master
Re: Helpful Hints
[/quote]
[/quote]
- Zombie Master
Re: Helpful Hints
Good tip. I'm sure my Crappy Tire (Canadian Tire) one would work just as well, and be nearly as cheapo!
Do check for hidden oil on your lift. It can sneak up on you. Give it a thorough inspection!
Re: Helpful Hints
From MS, "Why, yes there should. BUT, I would never be so petty as to point that out myself.... "
Notice how cleverly he turned it around so deftly? Shheeesh.
