84 R100RS wheel question
I don't know anything about the wheels on a 84 R100RS, so I am asking here. I have a request for shims for that bike. Seems to me that 84 is the year that they changed over to ball bearings.
Any comments by our knowledgeable members? TIA
Re: 84 R100RS wheel question
Duane -
Don't think so...the '84 was still the twin shock version so pretty sure it has the standard tapered roller bearing stack.
Snowbum indicates that from 1985, Airheads used a #6005 bearing. It appears that the R65LS, produced prior to 1985, also used the sealed ball bearings. Anton has a good cross references to bearings and part numbers here:
http://www.largiader.com/parts/crossref.html
Bamboo812
Post by Bamboo812 »
MaxBMW fiche shows standard roller bearings with shims for those years. My 1984 R65 with cast wheels had them too.
Tapered roller bearings for an 84. If the axle diametre is the same as earlier models, your shims will be helpful.
Might however be difficult to hold the shim in position prior to inserting the axle.
Bill Smith
Post by Bill Smith »
My '84 with snowflake wheels has tapered bearings.
Kurt in S.A. wrote:....It appears that the R65LS, produced prior to 1985, also used the sealed ball bearings...
Oddly just on the front. Rear wheel on the LS is taper roller.
Thinking some more re the shims and snowflakes, the shim can be held in place between the large spacer and wedding band by the plastic 'centering ring', if that's what they're called.
Thanks for the answers. Seems that it just got more complicated as time went on.
